Hey Mr. JLB,Anyone installed an oil pressure gauge on 68 ford galaixe or similar? If so where is the oil pressure sending unit and basically how to connect this thing?
Good choice of gauge IMO. Is it electrical or with the tube? Are you replacing a gauge or an idiot light? Or are you adding a gauge to the light.
I got the idiot light and I guess replace the light or whatever is easiest. I just need to know what's really going on with the oil pressure.
I did something along the lines of what JC mentioned Ms. American having in my '67. Mine had some cheapo three gauge set with electrical senders that was somehow rigged into the stock idiot light wiring and were reporting incorrectly when I got the car. Replaced that with a Sunpro three gauge mechanical set. I installed a T on top of the oil filter housing so I could retain the idiot light and use the mechanical gauge. I picked up a braided line to run into the cabin and it mates to a short copper jumper to connect to the oil pressure gauge.Hey Mr. JLB,
Ms. American 3.14159 has a set of Ford Gauges under the Dash. Volt Meter, Oil Pressure, and Water Temperature. The Oil Pressure Gauge has a "T" installed on the top of the Oil Filter fitting and both the Oil Pressure Gauge and the Sender Fitting for the Oil Idiot Light are connected to it.
Also, usually that Oil Pressure Gauge will have a plastic tube between where it connects to the Engine and the Gauge. That can be replaced with a 1/8" Copper Tube.
HTH
JC
As mentioned I would plumb it all in copper and ditch the nylon line, if that line blows you are going to have oil dumping into the cabin...
Picture of the T:
It's 3/8" if I recall correctly. As far as the temp side goes. I found a thermostat housing for an FE from a '69 that had a threaded inlet on it and relocated the idiot light sending unit there and put the gauge sending unit in the intake. Only problem with this is my 390 was the early '67 version with the large thermostat and the '69 used the smaller one. I modified the housing to take the larger stat, but there are adapter plates available (think survival motorsports sells one).Does anyone know what thread size is needed to t into the top of the oil filter housing?
Now, for the engine temperature gauge also included in the Sunpro kit, I was thinking of tapping into the thermostat housing, removing the air bleeder plug and putting the temperature sender there, hopefully using the adapter fittings included in the Sunpro kit. Is that a good place or is there a better location?
Thanks in advance!
Excellent! fordman289, thank you on both counts. If my stock idiot light temperature sender wiring will reach to the T-stat housing I may then do the same. My 390's t-stat housing already has the threaded port.It's 3/8" if I recall correctly. As far as the temp side goes. I found a thermostat housing for an FE from a '69 that had a threaded inlet on it and relocated the idiot light sending unit there and put the gauge sending unit in the intake. Only problem with this is my 390 was the early '67 version with the large thermostat and the '69 used the smaller one. I modified the housing to take the larger stat, but there are adapter plates available (think survival motorsports sells one).
The coolant temp sender needs to be located upstream of the thermostat. If located @ the thermostat housing it will not measure true coolant temp until the thermostat opens (remember, the thermostat fluctuates in opening/closing) and even then will not give a correct reading.Now, for the engine temperature gauge also included in the Sunpro kit, I was thinking of tapping into the thermostat housing, removing the air bleeder plug and putting the temperature sender there, hopefully using the adapter fittings included in the Sunpro kit. Is that a good place or is there a better location?
:tup:The coolant temp sender needs to be located upstream of the thermostat. If located @ the thermostat housing it will not measure true coolant temp until the thermostat opens (remember, the thermostat fluctuates in opening/closing) and even then will not give a correct reading.
There should be a fitting source in the manifold coolant jacket before the thermostat.
Yes, that is kind of my dilema. I was considering the sender location being after the thermostat, it would read cold until the engine warms up enough for the t-stat to open, and would fluctuate with the opening and closing of the t-stat as driving (or idling) conditions change.The coolant temp sender needs to be located upstream of the thermostat. If located @ the thermostat housing it will not measure true coolant temp until the thermostat opens (remember, the thermostat fluctuates in opening/closing) and even then will not give a correct reading.
