has anyone used a sway bar from a donor on the 67 galaxie if so what make and model do I search for the little sway bar I have is for the 289 but I have installed a stroked 460 and I used the station wagon spring up front and a set of Monroe load handlers but it leans a bit to much in the corners any suggestions
Hello taylorteam,
I encountered a similar dilemma on a '66. I bought the Hotchkis front sway bar as none of the other suggestions from factory cars fit worth a darn. Loads of pictures regarding it plus input from others. 3rd gen front sway bar upgrade.
Good luck
