Does the input shaft on a 390 t10 have a different snout than the small block like the toploader. I bought a t10 with the galaxie tailhousing and 8 hole main case and it has the long snout like a small block toploader
It seems odd that this one has a small block input, but has the long galaxie tailshaft. Someone must had changed it over the years and put it behind a 289/302 in a galaxie. It is 6 1/2 inches fron the main housing to the tip instead of six inches. This one is the wide ratio with the 2:73 1st gear.
I did not know the iron t10 was made with an 8 hole main case like the later toploaders either.
I built one like that and cut the input down so I could put it in a 61 Galaxie with a 428.
