1 - 9 of 9 Posts
Me again, just found out I have a green 8t gear. Problem is the 21 tooth cable gear is not enough. I had a white 24 tooth gear in the other trans, but I can't find it. Does anybody know if Ford or any aftermarket folks make a 24 tooth speedo gear?
Thanks,
Jeff
Try some of the Tranny rebuild shops and ask for the 7T tailshaft gear from 85 86 87 88 T5. If you're in the bone yard looking for T5s, look at the tag. You want one with number like 13-52-169 down to maybe 13-52-126. Some of those in that range could be 4 cyl and I don't know if they will fit a V8 tail shaft or not, but its worth a try. I just put a 169 tranny in place of a 199 an noticed that now my speedo matches my road speed. Used to be about 4 off to the high side. There is a file at this site that may help you:
http://www.veryuseful.com/mustang/tech/engine/images/T5Identifier.gif
On 2006-04-20 20:03, at38bc wrote:
SpongeBob, http://www.latemodelrestoration.com or 5.0resto.com has them, $10.50 + the freight. They have a lot of goodies
at38bc
Thanks...I got one from them before I found out that I could get one from Chrysler. By the time they added shipping (8 bucks) it was like 19 dollars. You can get it much cheaper at a Chrysler dealer for the same part.
89,5.0,5spd Hurst,410gear,cnc GT40P heads,TF cam,TF intake,65mmTB,76mass,UDP,Mac headers-exhaust,frame connectors,roller rockers. (sleeper)
<font size=-1>[ This Message was edited by: SpongeBob on 4/23/06 5:53am ]</font>
1 - 9 of 9 Posts
