On 2006-04-11 09:18, warrenyork wrote:
thanks toploader. will it work on the old 157 flywheel. I tried puttin an automatic on in when the car was a 3 speed and it ate up the ring gear.
Yep, T5s are different, they dont care if its an auto or manual starter. The modern starters are the same for auto & manual, and I've seen people successfully use both auto and manual vintage starters with T5s.
On 2006-04-15 19:43, josepheblack wrote:
I have about the same setup. I used a TKO500 with the original bellhousing and starter. The only problem I have is it "factory starter" hits a little at the tie rod end. I also want to go with a high torque starter.
Use a 92-93 Mustang, 5.0 Cougar starter, 89-91 & 92 CrownVic/Marquis starter. Other Ford mini-starters with the correct nose will work too, they used them in everything
