Wow, need help on this as the tech dept does not reference this when swapping from an AOD to a T5 in the 93 Mustang GT. The interlock cable that went from the auto shifter to the ign switch. What do I do with this? Remove it? unplug the wire harness?
Any help would be appreciated,
Thanks,
Jeff
Didn't think that the Fox Mustangs had an interlock cable of that description ... I could certainly be wrong however !!!
cheers
Ed N.
Don't know what yr it was from, just did a little sanding on the lower spot where it was hitting. Seams fine now. Now the new clutch set up is chattering on drive off. What next?
Thanks,
Jeff
