Banned
GM has a longer inputshaft and smaller dia. pilot bearing .
mods can be made for the unit to work . cost , might be less to get correct unit
Like Dan Said, you can MAKE it work. But will it be cost effective?
Other than outputshaft length and pilot size (they can be fitted with a bronze bushing no problem) it's 100% identical to the Ford T-5, because the same company makes them with different output shafts and bell housings (Which all bolt up in the same spot on the T-5 regardless of whom they were made for GM or Ford or Other)
cool thanks guys
