Working on buttoning up my 2 speed to c4 swap in my 64 and have a question concerning the slip yoke depth into the rear of the transmission. I’m using the stock length driveshaft from the 2 speed and not sure if it’s long enough based on the yoke depth at the rear of the transmission. Looks like it should be in further. Does this swap normally require the driveshaft to be lengthened? The pic was taken with the weight of the car compressing the rear springs.
169437
There is several different yoke output shaft depths. You have to have the one the fits all the way and then you bring it out 1".
Definitely needs a longer driveshaft, which will put the travel the correct 3/4"-1" (with the car compressing the springs.)
BTW, If the rear was freely hanging on the springs, the yoke will come out even more via the arc rotation of the spring at its front eye.
