It isn't one or the other. Torque and HP are simple math and always directly related. As already said, torque is just a fixed force at any instant, and this is multiplied over time into the HP number. So, an engine with 200 ft/lb of torque* at 2000 rpms is making half the HP (76.2) of an engine with 200 ft/lb of torque at 4000 rpms (152.4). Simple math.
From this, you can see why tuners don't care about the other number, and only look at one (usually torque). An increase in one is a direct but factored increase in the other. So, why the ongoing arguments about which is better, especially if they are inseparable?
The argument stems not from which is better, but when each should occur. To a tuner, a high torque number at all rpms is a stronger engine. Duh. It's higher HP too. Simple math. But to a driver, having torque
sooner to get things moving may be important, or having a peak later in the rpm band for a high HP blast down the straightaway may be the ticket to winning. Given that the typical engines we have make their best power in a 2000 to 3000 rpm band, the question is whether it makes it at lower rpms, or higher rpms.
To make it just a bit more confusing, engines can be designed with narrower power bands and higher peak HP, or wider power bands with lower peak but higher average HP In this case, the torque number is either played up or down, depending on whether average power is more important, or peak HP rating. Unless racing at a relatively fixed or narrow rpm range (offshore boats, circle track, NASCAR, air racing, etc.), the greater average power in your useful rpm range will usually get you to the finish line first. Because this shows on a dyno sheet as a higher and flatter torque curve, folks often say it's a 'torque engine'.
So, hopefully it makes some sense now that when hobbyists talk about which is better, they are actually talking whether a low-rpm or high-rpm oriented engine is better, or one with a broader or narrower power band. That, of course, depends on what you have and what you're trying to do. HTH
* For those that like to argue ft/lb vs lb/ft - note I said ft/lb instead of lb/ft. Ft/lb is just a force (scalar), and lb/ft is force with direction (vector). While a direction is necessary in power measurement and lb/ft would be appropriate, mechanical engineers established long ago that as TORQUE is specified (and therefore the direction), that only the scalar force is then specified - ft/lb. To say "200 lb/ft torque" is like saying "She has red hair hair".
