I bought a freshly rebuilt C4 with receipts saying it was built with the TCI Pro Super kit which includes the Trans-Scat shift kit. Is this kit worth having or should I put a transgo kit in it before I even install the trans.
Thank you, Ron
If you have the part number for the kit (the trans-scat kit) I can answer your question better. I have a cross refference of kits to others so if it shows up and matches with something TransGo makes I can let you know.
Paul
On 2006-08-11 07:08, 65whiteFastback wrote:
Paul the part # is 260100 Thanks
That number doesn't match up with anything in my cross-reference. If it doesn't work for you then the TransGo kit can be installed with just removing the pan and valve body.
It does look pretty close.
<font size=-1>[ This Message was edited by: PaulS1950 on 8/12/06 6:11pm ]</font>
