1 - 20 of 27 Posts
So my '62 Falcon only gets 8mpg or so. I put in 8 gallons, drove it to work a few times (I work about 2 miles from home) and now its empty. Its so bad I think I have a hole in my gas tank.
I'm assuming that the carb must be running really rich. But the engine runs well and makes good power. And I don't think a carb running that rich would make such a drastic difference in fuel consumption.
Some more info on the engine... best I can tell its a 200. The carb is a Carter of some kind, a YF I think. The engine has a little bit of an exhaust leak at the manifold. I recently installed Duraspark II, the plugs are gapped at .040. The timing is set at the highest point on the marker. The plugs look good, more like its running lean than rich. I haven't done a compression test yet.
Anyhow, I'd appreciate some tuning tips. I'd like to get it running well soon and I'm sort of in a financial bind right now so theres no money for me to get a repair manual.
Banned
Is your tail pipe really black and sooty? Otherwise you might have someone using your tank for their fuel. Real easy to steal gas from those old cars.
Just what I was thinking Gary. It should be set at 6/8* BTDC, and the idle at about 550 Rpm with automatic.
Erick you can tell by looking at he freezeplugs on the side of the engine, what you have. The 144/170cid engines have 3. The 200cid has 5.
200cid was not available from Ford in 1962, of course somebody may have changed it.
Ray
You should be getting at least 18 MPG. No way an engine can use that much fuel, it would not be running it would be way too rich. Has to be a leak.
I know the mustang gas gaps... when they fit loose, everytime you step on the gas from a stop, gas sloshes straight out the tank.
Where is your tank filler pipe? Low and in the back? Loose cap? Worn cap gasket?
<font size=-1>[ This Message was edited by: Mikes66 on 3/23/07 7:00pm ]</font>
Fuel line and/or tank has pin holes rust. Stick your head under the car and smell around. I think someone is steeling your gas or you would see a puddle under the car
If it is really dark under there, use a match so you can see what your doing.....
I have built 5 inline 6's and never got less than 20mpg. On one I suddenly dropped to 11mpg. I thought someone was stealing gas. It turned out to be a pin hole leak in the fuel line from the pump to the carb. It only leaked with the engine running and sprayed down at the ground. As soon as the engine cut off it stopped so no puddle under the car. Run your hand along the fuel line with the engine running.
Other than that I would have to say someone is draining your tank. I can't think of any adjustments or combination that would drop your mileage that much. If it were that rich you would see a lot of black smoke coming out the tail pipe.
Discussion Starter #12
Nice try...
Have you seen my signature?
Anyhow, the fuel lines are very old. And the tank does have some places where the undercoating is peeling off, but the rust in these areas doesn't look like it would leak.
As for the condition of the filler tube and the filler neck, they are low and on the back. The gas cap sits right under the decklid, and theres a 60 deg. bent tube than connects to the tank with a peice of rubber hose as a coupler. The gas cap is probably in terribile condition. The cap fits tight on the filler neck, but I am sure the rubber seals are gone/deteriorated. It could just be evaporation? I haven't seen any sort of ventillation/check valve on the tank. Doesn't gas evaporate and expand when its in an enclosed tank without ventillation?
I can see 4 freeze plugs looking at the side of the motor. I guess theres another one back between the starter and the exhaust manifold, that would be 5 making it a 200. The distributor is next to #1 cylinder on this engine, the 250 has the distributor in the middle of the block, right?
I took the filler tube off the other day and looked down into the tank, the metal inside the tank that I could see looks to be clean and rust free. I'll probably take the sending unit out this weekend and examine it.
Its a distinct possibility that someone is stealing my gas. I might invest in a locking gas cap. I have one on my Jetta and it gets great mileage
The gas cap has a built in vent. You must get a real good vented gas cap. For some reason the $15.00 auto parts store vented gas caps don't work like they should.
You can tell, as when you try to open the tank, it re-pressurizes... That is a very bad thing.
The Falcon gas tanks and filler necks are designed to NOT slosh out the back on acceleration... I have one
You very likely have a poor neighbor who never needs to go to the gas station or you have a pinhole in the fuel lines or a cracked rubber hose somewhere.
Without 3 other carbs at the same time your Falcon cannot run good and still get 8 MPG.
FE
On 2007-03-23 09:20, CaptVirgilHilts wrote:
Maybe it's a joke. Next week they will add gas to you car then you'll think your getting WAY better MPG! Stu
We have done that. We had a worker who was so tight that he is probably still spending the lunch money he saved from grade school. Anyways, he bought a new S10 truck and used it to come to work. Every 2-3 days we would add a gallon or two of gas to his tank. We did this for about 3 weeks and he would come in an tell us that he was getting nearly 40mpg. He was proud of the truck. Then we cut him off. He bitched and complained that his truck wasn't running right any more. He even sent the truck to the dealer to get it looked at. I would love to know that the service writer thought. LOL
It was a great practical joke--when gas was less than 1.25 a gallon.
Dennis
65' STANG, 3160 lbs
393W NA, 2.78 Toploader 4 Spd, 9" 3:70 Posi
Pro Comp Heads, Vic Jr. Intake, 750dp, CI Custom SFT, 10.2 CR, 1 3/4" Headers, Lakewood, Subframes, Caltracs
<font size=-1>[ This Message was edited by: dennis111 on 3/24/07 4:39am ]</font>
The Falcon has a vent tube coming from top of the tank next to the filler and goes cross beside the rear panel and loops back under the right quarter panel and back down through the floor behind the bumper (next to the exhaust pipe)
http://www.1bad6t.com/diagrams/fuel_system.jpg
You beat me to it Jeff. I was going to say that. Anyway, disconnect the vent from the tank and blow some air through it to see if it's plugged. Get a new sealed gas cap.
If you do narrow it down to a thieving neighbor, pivot your fuel filler into the trunk and dip it into a gallon container of water... or worse yet, bleach. Let him fill up on that all he wants, he won't come back for more.
1 - 20 of 27 Posts
