Hey All,
One of the things that CAN be worked on after the mosquitoes have retreated for the day, and it's STILL cool enough to be outdoors in the shade where Ms. American is sitting is to remove all the "caulking" from the Rain Gutters around the Front&Sides of the 3.14's Roof.
What is presently IN the Rain Gutter looks to be like a Ceramic Tile Grout, but it is all cracked and needs to be removed and replaced with something.
Once the "caulking" is out of the Gutter, there will have to be either the removal of the rust with an abrasive, or the applying of Ospho to stabilize the Iron Oxide to Iron Phosphate.
Then there will have to be some sort of filler reapplied to SEAL the rain gutters.
Have been considering using POR15, or there is a kind of Bondo that is a "clear" Green substance that can be molded into the Gutters.
But what I wanted to do first was see if anyone here has done this operation before and would be kind enough to clue me in on what is being gotten into.
Any comments or advice would be greatly appreciated by both Ms. American and myself.
TIA and I hope you all are well.
JC
JC
