Hello, first time writer long time reader. I have this 64 Galaxie 500, givin to me by my father in law, when I retired from the military. (didn't know it was in there). I want to install a tachometer but the 1964 shop manual states a specific way to install the tachometer. Connect techometer red lead to the tachometer block red terminal and black lead to the black terminal. My question is where do the green wire go without damaging the ignition system. ( I know the tachometer instructions states to place on the neg side of the coil ). Don't want ignition system troubles, the car has 33,000 miles on it and I put a battery in it, turn the crank shaft by hand, checked the plugs then placed a little oil inside the chambers, then started it up. Shes a runner with some rust.
Thank you for your support.
