Working on a project car. Found PO had removed stat and put in this blanking plate.
I'm quite a noob yet but I'm pretty sure on a street car a thermostat is a good thing (maintaining the optimal running temp, not "as cool as possible", too cold is almost as bad as too hot, right?) So I'm thinking I need to put one in. Of course now I'm realizing there's different size stats? It's a '69 429 with lots of extra "stuff"; edlebrock intake and 1407 carb. I'm currently fitting an HEI distributor so went for this water neck. Still working on fitment.
yes, restrictor plate would be a better term, so should I put a t-stat in there or just put the plate back? Someone did a lot to the cooling system, aluminium rad, electric fan, "custom" expansion tank of some sort. I could "assume" they knew what they were doing and put it back and only go to a stat if there's issues. I don't have a lot of confidence in this car's previous owner, there's evidence of "questionable" work all over the place and multiple issues so I doubt they ran it enough to even know if their "custom" cooling system was worth a fart. I already know the heater core leaks like a screen door on a submarine.
For a driver you are better off with a 180F thermostat. Buy a SuperStant, because they actually work for only a few bucks more.
FE engines typically run with a high-mounted pressurized expansion tank to keep the radiator completely full for better cooling, and it's far better for the radiator cores. The picture shows the stock location mounted directly to the intake manifold discharge, which has a vertical flange.
The discharge flange on yours is horizontal, so the PO probably had to make up something for the expansion tank. As long as it's above the level of the radiator and holds about a quart and has a legitimate pressure release cap you should be fine. Note that they typically run less than half full when cold.
okay, will do, now the question is which diameter stat? I would love to get one on the way home from work but I suppose I should go measure the hole first. I was hoping to go for fire tonight and drive it a little bit, if the elcheap crappo HEI dizzy works, if not, oh well, there's worse things a guy could be doing then plinking around with old Fords.
Not sure on expansion tank levels, there was only a little coolant under the neck, the hose was empty and the level was right at the restrictor plate (and clear silicone was used as a gasket......of course)
Later model FEs didn't use an expansion tank, that was only the early versions. A 429 never used one, and as long as the radiator fill point is higher than the engine water level, that is fine. The radiator works fine for that
That being said, a thermostat is a great idea. I tend to drill a small hole, very small, 1/16 at the most, to allow water and air to pass while waiting for it to open, especially the first time. It's much easier on the system, allows the thermostat to open more consistently and ensures there aren't any steam pockets to shock the heater core.
Hi Everyone,
I am looking for some guidance on the proper pulley set for the 302 in my '68 Falcon. Right now, the car slowly overheats and will not recover. I was reading up on pulley diameters and how it relates to the proper operation of the accessories but am still a bit confused on which...
I have owned my 1968 Torino (390 GT) for over 30 years and have always wondered this question. On most 1968 torinos...they have a single valve heater control valve while mine has a dual valve setup. I have wondered if this was a factory add on or some other reason. I have only found one other...
Need help with over heating 1965 ford galaxie 390 , I willtry and make a long story short, when I bought the car 8 years ago the enginewas rebuilt by Ed Wright in Brookville ohio, the car ran nice and cool neverwent over 170, it had long headers on the bottom gasser like headers . Istarted...
As some of you have seen I've posted a few questions regarding temp in the past and now I'm more stumped than ever. The car giving me the fits is my 66 Galaxie 500 with a stock 289, hei distributor and 500 cfm holley 2bbl. I was told it was rebuilt about 21,000 miles ago but I have not...
I need to purge the A/C lines, condenser etc on my car but I don't have a compressor. Does anyone have a work around for this? Could I taper down the hose on my shop vac and use it?
