This is the "F" looking vaccum that screws into the water neck. I suppose one oopening is a vacuum supply and the other does to the distributer advance. Question- is this thing worth a damn ie: do I go find a replacement or just screw in a regular vacuum for the disctibutor that till not be Thermostatically controlled??? I dont know what the benefit of the temp control on this thing is??
They were plummed in a few different ways, but generaly they the were connected to supply full manifold vacuum to the distributor if the engine tempature got above 220-230 degrees. Its a early emissions device, and one of the reasons emissons equipment got a bad mame. In other words loose it.
hmmm, that doesn't make sense to me. If temps get too high, i would expect that timing should be reduced, but if that switch supplies full vacumm, then that would mean increasing advance, no?
The thought behind advancing the timing was to increase the rpm at idle and thereby increase fan speed. At least that's what I read. In real life I'm not sure that will help things that much.
