The last 289 I built was in 1990 and I can't remember if I used thread locker on the cam thrust plate bolts. Is it a good or bad idea and if good should I use blue or red locker?
its an ok idea . if you do use it ... make it blueThe last 289 I built was in 1990 and I can't remember if I used thread locker on the cam thrust plate bolts. Is it a good or bad idea and if good should I use blue or red locker?
