i just installed a carter carb on my 69 cougar and it seems as if the throttle cable is too short because when it is hooked up the gas pedal stands up and it is hard to push down, how can i fix this let me know thanks a lot
Ok, I would check for kinks in the cable and make sure that there is nothing pinching the insulation around the cable, ie..moves freely. If that all checks out good I would check to see if it was routed right from the bulkhead to the carb..hope this gives you a startin point
