Hello,
I would like to modify the gas/throttle linkage in my 68 Fairlane to a cable operated system. Anybody done this in this (or similar) model car? If so, what parts did you use? I have been looking at some of the Lokar products and generic versions, but I'm not sure if the universal version will fit, and I'm also not sure if the Lokar Mustang replacement unit will work either. Thoughts?
It has the factory mechanical system now, sans the bellcrank. I added an adjustable linkage rod to eliminate the bellcrank, which isn't optimal, but it works. I would like a cable operated linkage so it will be compatible with any and all future mods, and ensure proper WOT opening as well.
Thanks!
