Hey there,can you use the stock timing chain cover off a 302 that has stock v belts and pulleys on a sepentine setup? Thanks
yep. The only difference between the later ones and the early ones are the timing pointers and fuel pump mounting. The later ones have a "window" for the timing pointer and most of the early ones had a bolt-on pointer. Also, the later covers have the fuel pump boss drilled, but the hole for the pump arm is gone, you have to punch it out for a mechanical pump. Hope this helps
