I believe my timing cover is toast, looks like the water jacket corroded.
Font Bicycle part Automotive tire Auto part Wood
Automotive tire Wood Automotive wheel system Bedrock Auto part
Any suggestions on purchasing a new one? Are there and specific differences between years for these, or specific part numbers for certain years?
Also, to install the seal, do you guys recommend a special tool?
And, is an alignment tool necessary for installation?
Thanks.
Cloud Water Sky Grey Handwriting
Rockauto or ebay. Yours is for EFI so you can use one without a provision for the mechanical fuel pump or block it off if it is there.
Mine is NOT EFI, it has a carb and a mechanical fuel pump. However, I would think the one from Rock Auto should work.
