My engine builder tells me the 408W has a compression ratio of 9.5:1 and should be OK with 92 octane fuel and no more than 32* total advance. My distributor has 26* mechanical advance (no vacuum)...all in by 3000 RPM's and I have been running 10* initial for a total of 36*. Today I set it to 6* initial and could tell a big difference in the way it sounds and runs....Still strong, but louder and idles rougher. It seems to idle better at 10* initial!!
I have heard you guys talk about 38*-40* and more total advance and wonder where I should run it since it is so loud I can't hear it knocking....If it is???
I think it runs better with more base timing and I guess I can change the mechanical advance to less than 26* if I need to keep it in the low 30's total advance??
Suggestions.....Thanks,
Cobrajack
Cobrajack
