New holley 600vac.secondary, no vacuum leaks on a stock 390. I changed the dizzy from 15l to 10l under the point plate? When I step on the gas in gear she just sucks air and treis to die. Could this be fron not enough total timing? Initail is set at 10 with 20 mech. and 10 ported vacuum ( I believe ), I wonder if the initail needs to be bumped up? Thanks for any help.
I switched the carb out to anouther new holley, returning the old as damaged. Put it on, set the choke, air mix and she lays down rubber, like she never did before. Thanks to all for your advice.
<font size=-1>[ This Message was edited by: 69galaxie500 on 3/7/06 10:49am ]</font>
