I need to be sure before I buy.I need a timming pointer for a 1974 Maverick 302 engine.I seen a timming pointer on ebay for a 302 Mustang engine and it will fit a Mustang 302 engine up to 1973.I would think the pointers should all be the same and it will work for my need.The 1973 and 1974 pointer are the same arn't they ?
There's at least three different pointer and balancer combos. Would need to know about your setup? Which balancer do you have? What side is the water pump inlet on? What timing cover do you have? A pic would help.
Thanks for the reply.after spending the time looking on ebay for another pointer and then posting the question on the forum,I went out and looked more closely in the garage and found the original 1 for the engine,Thanks anyway.
