1 - 11 of 11 Posts
Toploader id is as follows RUG-AT.It shows it from a 70 fairlane with a 351 in it.Will it work in a 65 mustang with a 289 in it.
The bellhousing from the 351 should work ok if thats what you mean by a big block.The smaller 157 tooth one would probably give you a little more room though.
I think were talking about the bellhousing to block bolt pattern,which is definetely different between a big block and a small block,where the tranny bolts to the bellhousing is the same for both.
First a 351 is a small block with a taller deck height.
A top loader that fits the 351 will bolt directly to the 289 bellhousing as is. (assuming a 6 bolt block). I know. That's what I did....Before I got smart and installed a T5.
I was working on the premise that you may not have a bellhousing and would have to go find one ...
If that is the case ... Just be sure to get the correct one before you shell out $$$
That's all
Discussion Starter · #10 ·
Well it has the 351 windsor bell housing it should be the same as my 6 bolt bell housing 289 block am i correct.
1 - 11 of 11 Posts
