hey im workin on my 71 torino gt and ive got the hooker 6115 headers....they look pretty tight are they gonna clear my oil filter on my 460? its gonna be close...
I put the 6115's in over one month ago. Yes they will clear the filter but you got to remove the filter when you install the headers. Mine were very tight around the chassis at the control arm.
The passanger side is the easiest. Dont forget to retighten the screws after a few thermal cycles.
factory mechanical lets you know when it needs to be replaced by blowing fuel through a wheep hole straight at hot exhaust manifold?! has there ever been deaths because of this? is there a fuel pump replacement not designed to kill you,thats available on the market?
Greetings from Phoenix, AZ!
I'm looking for a set of the hubcaps that Ford used on several different models from 1970 until 1973, I believe. I know by simply changing the center cap, these covers could be used on various models. I know they also came in 14" and 15" versions.
I located a set...
