I have a 2001 f-250 Super Duty {crew} with a 5.4.When it had 40 K ,it started to chatter during shifts the dealer replaced the torque converter and it was fine.It now has 106 K and started chattering again.I'm going to replace the converter again.My question is is this common and can I upgrade the converter instead of putting in a stock one.I tow on the highway with it and use it to put by boat in on ramps.Thanks Mike Sr.
if it si truly chater as in clutch chatter in between shift,need a shift kit from trans go,it has the goodies to help quicken the clutch aplication of the torque conv.
