most all intakes are torqued to the engine's spec's and also in the torque sequence. This includes aftermarkets. If this is a windsor, just be careful of the end bolts. even the cast iron intakes have been known to break off on the ends.
Yep. They can break off. You can also overtighten some of the inner bolts and break off the boss on the head.
I just removed my intake and found the boss broken off. Oh well, nothing a little bit more blue RTV can't handle
I just bolted it back up and ran a very small extra bead along the head-manifold gap and smoothed it with my finger. No leak.
22lb-ft , but the sequence is to complicated to put on a web board . Well I think this is it
5 1 1210 4 8
< - - - - - - back
6 3 9 11 2 7
This is what I can remember off the top of my head but check it in a manual , atleast you know what to look for and if you cant , check back with me tomorrow and a will find out forsure , but this is close enouf and as long as you go in steps you will be ok just go around at least 3 times till you reach 22 lb-ft , no more than that that is the spec no matter what manifold they are al the same . Oh did you guys know that over torqueing intake bolts can tear up you bottom end , it pulls on them heads , in turn pulls up on the block and distorts the mains , just a little tid bit , neat huh!
I was really surprised when I found this out.
lowside
