Hi,I needed to know the torque setting for a rear main cap on a 2 bolt main 89' 5.0. One manuel says 40lb and other says 70lbs.Thanks Mike Sr
mains are 80
Thanks , Whats a good book on 5.0's that would have basic and performance rebuilding info?
Thanks again, but one of you said 70 and the other 80 can someone clear up which it is. I guess I could go in the middle at 75.
The torque on the main caps for the 89 302 is 60 to 70 lb. feet of torque.
The 351W is 95 to 105 lb. feet
This torque spec is with clean threads lubricated with engine oil.
Paul
