Does anyone think that 70-90 ft lbs is too much for the pulley bolts to be tightened. Kinda in a pinch right now. Sorry if I am on the wrong board. Put them at 50ft lbs. Thought the bolts would stretch or break.
Greg
My old 1972 Chiltons manual says the same thing. It looks like they copied directly from Ford's engine assembly manual and I'm guessing the factory engine assemblers received the pulleys and dampers bolted together and just needed to install the damper/pulley assembly as one piece.
