For those of you running TW heads, where are you getting the best top end power with your timing? Combo details are in my signature. I'm currently running 15* initial w/ another 20* of mechanical advance, all in by 2500rpm's. Sound about right, or should I advance/back it off?
Getting ready to step up to steeper gears (4.11's or 4.33's) and more torque converter (2800-3000) so I can really twist its' wick. Right now, it'll spin to 6300+ without breaking a sweat. Just curious what everyone else is running.
Kevin
PS... I'm running a 28" tire in back (275/60-15)
'72 Gran Torino Sport...357W w/TFS TW heads, RPM AirGap intake, Bigs 750DP, CompCam XE274, RHP re-curved Duraspark dizzy, FPA long-tube headers, full 3" X-pipe exhaust w/ Hooker Aerochambers, C6 w/ 2000+/- stall converter & 3.50 gears w/ Powertrax locker
<font size=-1>[ This Message was edited by: OleDutchD on 4/13/06 2:42am ]</font>
· Premium Member
The combustion chamber is very efficient so it does not need a lot of spark lead. I have seen them run well w/ as little as 32* total. But you will have to tune in what works for your total combo.
Depends on combo, compression, cam, octane, Etc. but 30-34 degrees is a good starting point and 14 initial is also.
Your fine right there. If it doesn't knock yet try a little more till it does then back it down some. I think right now I at 20 initial and 32 total.
We're running at 34* total (locked out) on an '86 5.0 stock lower end with TFS TW heads,TFS stg II cam, 10.2 compression flat tops. It's a bracket car weighing 2700# and running a best of 11.73 at 115 mph. It likes the timing best at 34* with our setup.
Terry
If I remember correctly I ran around 42 deg total in a light four speed car w/ a custom solid cam and about 9.5 comp. with the TF's. Sounds like alot but that was what it liked. It pulled hard all the way to 8K.
<font size=-1>[ This Message was edited by: toploader on 4/13/06 12:21pm ]</font>
