Need help again, does anybody know what the tps voltage should be when setting the idle? The big black Ford book the dealers use is useless as tits on a boar hog. Change is out, turn it 10-20 degrees your done, hooey. 93 ,5.0 L. I thought you set your idle, shut it off and then set the tps. .9980 volts I think?
Thanks, Jeff
Thanks, Jeff
