HOW CAN I IDENTIFY A TRACK HEAT INTAKE OVER A STREERT HEAT? BECAUSE A FRIEND SELLS ME ONE BUT I THINK IS THE STREET VERSION.
FE those are just model names =). Like Victor Jr versus RPM intakes.
I also don't know how to tell the difference though, sorry.
Cris
Its hard to tell, but the track heat upper plenum is not as wide as the street heat. Both intakes can be black or silver.
I believe you can tell by the port dimensions. All the upper plenums are available in black or silver. The trick flow site has all the dimensions to tell the difference. Both are excellent manifolds.
Chris (I run a track heat)
I think the street heat heads have ports for EGR (emissions legal) and the Track heat heads do not
The difference is in the upper...they use the same lower. The Track Heat has 12" runner lengths whereas the Street has longer 15" runner lengths.
To tell the difference, locate the part number underneath the upper (again the lower is the same). The part number for the Track Heat upper will end with the number 2 and the Street will end with the number 1.
<font size=-1>[ This Message was edited by: 87stang on 1/26/07 1:05am ]</font>
