1 - 9 of 9 Posts
I'm going to add a trailer hitch receiver to my F250 XLT SuperCab and am trying to decide if I should get a bolt on reciever or have one welded in.
I was thinking a Class IV would be plenty as I will tow small trailers like toy haulers and car trailers.
Any advantage either way?
Thanx, Mike
<font size=-1>[ This Message was edited by: finkster on 5/23/06 8:04am ]</font>
For what your going to use it for I would just go with a bolt in.. and you can do it your self.. I think...
Tim
Banned
Bolt in, but use grade 8 bolts, not the hardware store bolts.
Weld...always weld for a tow hitch. This is one of those areas where that extra margin of safety comes in handy if you ever have a load that starts to get away from you.
I pull a 10K trailer at max GCWR with an F-250
I'd bolt it and use the stock or equiv design. With the stock setup (bolted on the bottom and brackets up the sides) you'll pull the frame out from under it before you pull the hitch off
Remember, any receiver is held by a single pin......
However, do check bolts periodically. Never found a loose one, but good piece of mind before a pull
Thanx for the input!
Any particular brands that are better quality than others?
Draw-tite, Valley, U-Haul, etc...
Banned
Use Draw Tite, never had a problem in 15 yrs with 2 vehicles that have them on.
THATS RIGHT ,WELDS WILL CRACK AFTER TIME !! HARD BOLTS AND LOCK WASHERS !!! I PULL A TRAILER 50,000 MILES A YEAR .WHEN BUYING THE HITCH LOOK AT THE THICKNESS OF THE TUBING AND FLAT BAR THAT ITS MADE OF ..
1 - 9 of 9 Posts
