Just a little confused on the wiring can anyone tell me why i have two of the same white wires coming out of the silinoed I know one goes to the transbrake switch where does the other go also is it true that reverse does not work without this hooked up? Thanks for the help
One is ground, doesn't matter which.
Depends on your VB if you need to activate the switch for reverse. Most C4 VB's don't, though some of the newer ones may.....you will soon find out!
