I test drove it today and this is what I observed.
1) 1-2 shift is extremely early.
2) hardly noticed any automatic down shifts and Manual down shift seem to take a second or two.
Haven't tried adjusting the modulator yet for the up shifts but I will try that tommorow. Is it a allen wrench or screw driver that you adjust it with? Also will adjusting it effect down shifts?
One other thing when I had to change governors due to it smashing into the tail housing, I took the springs from the original governor and put them in the new one but I am not sure if the valves were the same.
Any help or suggestions appreciated.
Screw the modulator in.I weigh mine on a scale to get the correct lb rating. Usually they screw in about 4 turns to get the right weight. Screwing them in also makes the downshift more responsive too.
