We are currently in the process of swaping a 302 for a 351C in my 70 fastback. We got the 302 out were comparing the 2 flex plates and the 351 is bigger and will not fit in the 302's c-4. We really do not want to go the trouble of changing transmissions. What can I do? Can I keep the stuff off the 302 and put it on the 351? Or will the starter not have enough power with the different gear ratio to crank over the bigger engine? I was wondering if there was a bigger bellhousing that I could get that would bolt up to the c-4 but at the same time be able to accomidate the 351 flywheel.
ANY help would be great!
Matt
Matt
