need to redo the linkage from the steering wheel column to a mouthed floor shifter. its on a 67 390 galaxie 500.
Anyone know how to do this?
If it is a c6, the selector at the transmission had two different types. floor shift and column shift.
I've got both in my parts pile. you *could* hunt and find original parts. Or just get an aftermarket floor shifter, most require you to cut the original shifter arm and install their own.
Either way gets the same thing done
