Hey guys,
Recently I got a new Performance Automatic PA26101 C4 transmission which ended up not fitting my old belhousing properly so I got the PA bellhousing as well. Managed to get it hooked up and it was sounding fine for about 5 mins and then a noise started... I've attached a link below to a video in my google drive which shows what it sounds like when manually going through the gears. It sounds fine in P or N but the same noise is heard in all the other gears. After some quick googling it could be the torque converter but this wouldnt have been my first guess given that its only about 2.5 years old, also from PA (PA26212 stall around 2400rpm, "engineered to withstand the punishment of full throttle starts") and was working perfectly fine with the old transmission.
I'd really be grateful for any and all suggestions. Thanks!
TLDR:
TLDR:
- Transmission noise when in gear, good when in P or N
- Full Performance Automatic set up now (faily new torque converter, new bellhousing, new c4 transmission)
