I just acquired a bad old 69 Lincoln. From what I understand (though I know nothing about Fords yet), it has the 10.5:1 460 motor. It ran pretty well on the drive back from where I bought it (about 500 miles) considering it needs a tuneup badly. The Motorcraft carb was running pretty rich most of the way, the wires and plugs are ancient, and I'm sure the points are off. Anyway, I plan on investing a little money on waking the engine up (looking for mean torque on the street), so I need some advice on the following ideas:
* Upgrade the points to electronic ignition. Should I just go for an old electronic Ford distributor? One can be had for $30. Then it's a matter of figuring out the advance curve.
* Cam and intake? I was thinking about Edelbrock's Performer line since the car's a tank at nearly 5000 lbs. I still need to check the rear-end; not sure if the differential is conventional or limited slip but the gear is probably 2.8 or 3.0.
* I have a Holley 800 DP sitting in my shed that's in great shape and doing nothing. Would this be too much carb? I think the primary jets are 73, which is probalby too big. Would it be a vain endeavor to try to get any sort of fuel economy from such a monster?
* Shift kit for the C6?
Any help appreciated!
