I bet this has been covered before, but can someone tell me the best way to get the chrome trim frome around the windshield of a 64 2dr ht , and the trim peice that runs along the rain rail ? Thanks for ant help JD,
Thanks. Kinda figured that but was hoping for a easier method.
I take white lithium grease and put thin coat on rain guter first, then put trim on. the grease will make it easier and help from scratching paint.
I also use white lithium grease when assembling other parts on fresh paint (example under any washers, threads of screws, etc.) it helps keep the fresh paint from pulling/wrinkling or scratching
And as falconwagon said make sure you use masking tape to protect surrounding area.
Lou
