On the tripower intakes, how are the runners separated? In other words, which barrels of which carbs feed which cylinders? Man, lots of whiches! I'm under the impression that the center carb feeds all the cylinders, but the outer ones add to it.
Usually, it is a dual plane. All carbs dump into a split common intake plenum. Now there are (were) single plane options but I doubt if you will ever see one.On the tripower intakes, how are the runners separated? In other words, which barrels of which carbs feed which cylinders? Man, lots of whiches! I'm under the impression that the center carb feeds all the cylinders, but the outer ones add to it.
Yes, same theory. The 4 X 2 dual plane intake is also the same theory.So it acts like a 4bbl dual plane? That's what I figured, but I was hoping for more specifics, like the driver's side of the center carb feeds cylinders_ _ _ and _. The driver's side of the front carbs feeds, blah blah, you get the idea. You can't quite tell by looking as some of the paths flow under the carbs. I guess I could pull them all off and look inside better.
Sure... I can try.Kultulz, can you tell me what that single plane is? I don't recall ever seeing one before for an FE?
Scott...
:frown: ...sheesh...I don't think he was asking what a single plane does, but rather who makes that one. I'm curious too.
To be clear, most 3x2 intakes are dual-plane (also known as 180°). All the carbs feed all the cylinders, but all of the left barrels are connected to 4 cylinders with one plenum, and all the right barrels are connected to the other 4 by the second plenum. While there are rare exceptions, the vast majority of even-fire 90° V8 engines (everything 1960's and up, including the FE) are divided with one side of the barrels feeding cylinders 1-4-6-7, and the other barrels feeding 2-3-5-8. Other brands use the same layout, but the cylinders are numbered differently.On the tripower intakes, how are the runners separated? In other words, which barrels of which carbs feed which cylinders? Man, lots of whiches! I'm under the impression that the center carb feeds all the cylinders, but the outer ones add to it.
