1 - 19 of 19 Posts
So someone blocked the PCV on the back of the intake with a flat plate. The car stinks at low speeds and occasionally puffs out the hood vents at stops. I'm wanting to know if the stock plate back there is a screw in PCV, or what. If so, is it just pipe thread? I'd like to pull the plate they put on and machine it, but need to know if it is grommet or screw in.
Thanks!
Oh also, I know there is a search function. Couldn't find a simple answer. Not after draft tube, valve cover, vacuum pumps etc. Just the stock setup.
Double thanks!
Yep, that's the car. Just crankcase puffs vapor/fumes sometimes. I've seen it right out the breather/fill cap a couple times, like what ends up all over the valve covers when Ricky Racer ditches his PCV. Stinks too. I want to get it hooked up asap, like today.
The stock setup is a stamped steel plate with a bung in the center. It uses a rubber hose that come up, makes a loop, then enters the PCV valve before going into a 45* fitting in the intake under the rear carb.
Great thanks! I saw a few pics of various setups on Google, but didn't know which was original. Now I do! Sadly, I realized they plugged the big hole on the intake with a huge freeze plug. Hopefully I can get it out without making any debris fall into the engine.
Discussion Starter #7
Well, should have been easy, but it immediately fell into the hole. Luckily I was able to grab it with my fingers. The fit was so loose it just came right through the hole with no effort or tools.
So looks like after all that, I am going to have to do a little non-original arrangement anyway. The car has a C6 and uses a vacuum modulator. I'll have to put a tee in the intake as it doesn't seem to have any manifold vacuum ports.
Stupid PCV is special order. So much for having this done today.
Discussion Starter #8
Can of worms time. How do I know the stock PCV will work right if the engine internals are not stock? If the PCV has to be a certain one, how will I know which? If it really matters that much, how do the ones from Summit that are universal in a nice aluminum body work for any application?
Discussion Starter #10
Yes, that's the easy answer. I know how they work, I'm asking about how to choose one for a modified application as spring pressure, and flow vary between types. Too much flow too early, big vacuum leak at idle.
Discussion Starter #12
I just discovered a company that makes a dual adjustable unit for idle flow, and cruise/acceleration flow. I might need to break out a chunk of aluminum and go to town. Looks like the stock setup might not be ideal.
...hmmpf...
Referring URL?
THANX...
I could email you a picture of the factory set up. The orginal app was the Hi-Po 390 and 406's so a pcv for one of them should be good. Ford used the same set up on the 427's too.
1 - 19 of 19 Posts
