As you did not mention, most of the early era Fords had fuses connected in on the headlight switch. It is not required, but I often loosen the whole switch on mine to access them. There is no separate fuse noted on the holder for turnsignals that I remember.
Wm.
Check your flasher relay. It is attached to the rear of the speedometer housing.
