I have a 71 torino gt 351 but got it with a 429 in it with c6 trans... Here's the problem need a rear u joint its 3.62 in on drive shaft and i thinks its a 3.23 but cant find one like the one i took off.. need some kind of part number:confused:
Any drive shaft repair shop will have the u-joint.
Um the rear may be the small u joint while the front is the larger u joint? correct? takes a special u joint. I did this to my Galaxie. I will try to find the part number, I ordered it from Sumitt.
part M-4635-A is the u joint I used,
