1 - 13 of 13 Posts
IT ONLY HAS *0A146173* HOW CAN I TELL THE REST OF THE VIN? OR WHAT THIS CAR IS? THE VIN PLATE IS DESTROYED
0 is an 1970
A is built in Atlanta
14 is the body serial code and I can't find a 14 in the books I have but I don't have a 1970 book
I believe 6 is for a low compression 302 for Export only.
The following 1 means it's a Ford division car (If it was a 5 it would be a Mercury, a 7 means Lincoln)
The rest of the number is the consecutive unit number. It would mean that it is the 73,XXX Ford ordered for build in Atlanta.
Do you know what model the car actually is? or is this a total shell? Stu
HMMM a Cobra should have a body serial Code 38. Is the body a "sportsroof" with the tunnel back or is it a standard "formal" roof I'm just wondering if the 14 is a 70 1/2 Falcon body serial code? and a 429 should be K N C J or P depending on the flavour.
The Falcon may account for the lo po 302 motor code?????
Stu
The last 6 digits are the unit serial number. There are no body or engine codes in that partial VIN.
Really smart decoder guys can tell by the 6 digit number what model of car it is likely to be, but I'm not one of those guys!
429 engines in 1970 and 1971 were N, C, and J only. K is a 302-2v.
Good luck,
Greg
*edit*
Forgot to mention that Kevin Marti can provide a full workup on the car with data he has compiled from Ford. That data will include everything about the car, options, color, engine, trans, etc.
Check at www.torinocobra.com for more info, those guys are really helpful.
'71 Torino GT - 545 stroker, Edelbrock CJ heads w/ 11.8:1 compression, victor intake with 850 DP, C6 w/TCI streetfighter converter, 4.56 detroit locker, a/c with full interior
http://www.fordmuscle.com/readerscars/showpic.php?id=963</a> " BORDER="0" WIDTH="200" HEIGHT="100">
<font size=-1>[ This Message was edited by: GregP on 6/20/06 7:43am ]</font>
GregP is correct. That is a 'vin derivative' and consists of the year/plant/and sequential. No other info is in that derivative.
K is a 429 2V F is a 302 2V. Unless the Ford Shop manual is incorrect... Stu
No K code engine was offered in the (US) midsize in 70-71. Isee I had an unfortunate typo in my forst response! F is indeed a 302-2v.
Sorry for the mixup.
Greg
Banned
Just a question, what body style are you working with here? And is the door tag still readable?
1 - 13 of 13 Posts
