will under drive pulleys from a 5.0 fit on a older 302 balancer? Or is the bolt pattern different?
The 5.0 used the newer 4 bolt pattern for the damper pulley. Early small blocks were 3 bolt. I don't know when the change was made but you could just look at your damper and see or feel for the bolt count.
my balancer is a 4 bolt. its off of a 72 ford 302. will under drive pulleys from a late model 5.0 fit? if so what brand is better, march or what?
