Hey guys,
My father's about to have his 64 worked on a bit (I'm not near home and he's too busy on the farm). We bought a lot of engine parts (edelbrock top end). I posted here last summer when we were working on it a bit.
I was thinking about some other mods to do. In particular, we put in a dual master cylinder, however, we're still running drums all around. I noticed there's a bracket on ebay to convert the front setup using S-10 calipers - has anyone else used this or know if it's a good idea?
I was also interested in the Ford 8.8" rear - but the modifications seem like they might be a hassle w/ our capabilities and work schedule. Anyone have an idea of a better option to get a posi rear setup that they've tried? It's currently got the stock open 3.25 setup (4 speed close-ratio toploader).
Basically, my dad isn't that fond of finding 2 rear ends (likely the 3.55 gears) and modifying them. Maybe it's not that bad, but it's easier to give a mechanic a few parts rather than a project like that - so in that sense I see what he's saying. Maybe it's not that bad?
Any recommendations for these two areas would be helpful. Thanks guys!
Cooker - The rear end change is not as complicated as you thing. A late explorer disc brake posi rear (with mid/high 3 gears) is not as big a deal. You only need 1 rear but the shorter axle from the second. You'll have to cut the long side down to get the houding under the fairlane. I believe it's been done on this site.
As for the front caliper deal ... I can't answer that. I can only say that Fatman Fabrication had a nice drop spindle/disc brake set up for short (kinda) money.
Good luck.
6T4 Bolt
Check with Scarebird also for disc conversion brackets.
Here is the write up on the 8.8" narrowing. My Dad and I also narrowed one for my 65 Falcon. It's pretty easy.
http://www.fordmuscleforums.com/rear-end-articles/495110-31-spline-explorer-axle-swap.html
Jet
I see someone is using the Scarebird bracket in a kit for $415 & $70 shipping (ouch). I could do better than that buying the parts myself, right?
I'm going to call up a few places tomorrow if I get a chance to see about explorers w/ the 8.8" rear.
Thanks guys.
