I finished pulling it apart this evening. I found a hardened 26/24 spline shaft, "H" servo, 5 foward clutches, and a wasted set of high/reverse clutches. Wasted to the point that there was no friction material on any of the clutches and the piston had overtraveled and wedged itself sideways. Talk about a pain in the butt to get the spring retainer off and piston out.
I'm thinking of using Alto clutches. I plan on adding one disk to the high/rev and may add an extra to the foward. Should I swap both bands to Kevlar or just the intermediate? I also plan on using the BURLY4X4.com valve body mods, drilling the high/rev drum, and removing the check balls from the stator. Any other suggestions?
I think I should have a pretty stout little tranny when I'm finished.
