I finally got my junkyard 5.0 and I'm trying to break it down to take to the machine shop. Does anybody have any hints on taking the upper intake off? I tried wedging a crow bar between the valve covers and the left hand side with a slim peice of wood but it doesn't budge. I don't want to wedge a screwdriver on either end(front or back) cause of the soft alum. Need help, thanks alot.
There are 6 bolts holding it on, 2 in front, 2 in back, and 2 under the HO trim plate. Should lift off without any trouble. You have AC hose, and vacuum lines to get loose, remove the water lines, and the throttle bracket.
Ron
If you have to force it, STOP, LOOK, LISTEN, and be careful if you try to force it 'cause somthin is WRONGGGGG !!!!!!!
Glad that helped. I can almost do it in my sleep now. I'm getting tired of not being able to get mine to run right, read, I've had it off a lot.
L8tr, Ron
Thanks for all the responses. I got both parts of the manifold off, is it normal to see oil and carbon inside the runners. The engine is off a high milage cougar and I haven't seen anything like that( first fuel injected tear down). What do I use to clean them out and how? Thanks .
· Premium Member
Re: upper intake removal- torx screws?
long dead thread...
pulling the upper off my old Mark VII, cant get those torx head screws to budge on the upper intake cover plate...soaking in pb blaster right now, any other suggestions?
maybe carb cleaner, maybe heat, maybe just drill them out...figured its a common problem with the steel screws in the aluminum, hoping someone might have a magic solution :)
· Premium Member
They don't want to budge because they're almost a stretch to yield bolt. The bolt is in there nice and snug and you gotta hit it Hard and Fast with HP, not slow with a lot of pressure like torque...
That's why a 3/8" impact of a butterfly 3/8 air wrench are excellent for taking them out.
Get as little as 1/4th of a turn on the head and they'll come out with your finger tips...
