I don't know the measurements, but you want to know the distance flange to flange, leaf spring perch center to center. You can use a Mustang one I hear, but it is wider. I'll be at the swap meet too.
If you measure the 4 lug rear you have the dimensions will be the same.
I just found the stock rear is 56" that should be drum to drum. The 65/66 Mustangs are 57.25 and the perches should line up the same.
<font size=-1>[ This Message was edited by: latamud on 4/1/06 2:40am ]</font>
